CAD tip CAD tip # 7723:
Question
If you want to quickly close (abandon, quit) all drawings opened in your AutoCAD session, without saving and without any prompts and questions, you can use the following VisualLISP macro:
;Quit all drawings without saving (CAD Studio - www.cadforum.cz)
(vl-load-com)
(defun C:QuitAll ( / dwg)
 (vlax-for dwg (vla-get-Documents (vlax-get-acad-object))
  (if (= (vla-get-active dwg) :vlax-false)(vla-close dwg :vlax-false))
 (command "._close" "_y")
Save this code to a LSP file (or download the ready-made QuitAll.lsp) and load it in AutoCAD using APPLOAD. The command QuitAll then closes all opened drawings and leaves AutoCAD in a "zero-doc" state. Please use this command carefully - all unsaved changes will be lost!
To quit multiple DWG drawings including optional save, use the Express Tools command QQUIT.
ACAD
12.1.2011   31830×
this tip shared by ARKANCE experts applies to: AutoCAD ·
Tip 14998:What is the difference between two open documents, two open Inventors, and two Inventors on two different PCs?
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 14414:Link geo-tagged photos from your mobile phone to AutoCAD DWG maps.
Tip 14192:MLfillet - how to fillet multilines in AutoCAD?
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Back    All CAD Tips
Categ:
