New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 7716:
Question
If AutoCAD does not show the prompt "Command:" but still accepts typed commands, check the setting of the variable NOMUTT (no muttering). When set to 1 (one), it suppresses AutoCAD command prompts.
ACAD
8.1.2011    13134×
applies to: AutoCAD ·
Tip 14250:How to select all lines of the same length or boundary polylines of the same area?
Tip 14135:New special code ^] for menu-macros, easy object selection.
Tip 14045:In my AutoCAD script file (.SCR) I cannot enter a name containing a space.
Tip 13977:How to publish a PDF to the same folder as a DWG drawing in AutoCAD?
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Back    All CAD Tips
Categ:
