Over 1.122.000 registered users (EN+CZ).
CAD tip # 8037:
Question
If you need to remove/reset formatting styles assigned to individual cells in a Table object in AutoCAD (e.g. pasted from Excel), you can use the CADstudio TabReStyle utility.
TabReStyle resets cell style in selected table objects. Load it with APPLOAD, start the TABRESTYLE command and select the complaining table(s).
You can download the free TabReStyle utility from
Download
ACAD
14.6.2011
15552×
this tip shared by ARKANCE experts applies to: AutoCAD ·
