CAD tip CAD tip # 8030:
Question
With the free AutoCAD add-on utility CADstudio Click2XLS you can automatically export all "clicked" coordinates to an Excel table.
Download Click2XLS from DL Download, load it with APPLOAD and start the CLICK2XLS command.
This either creates a new Excel table or connects to an existing (opened) table at the selected cell. Any clicked points will be then copied over to individual rows in the Excel sheet.
This video shows how it works:
Since version 1.4, Click2XLS also contains the Text2XLS command which transfers picked drawing texts to Excel (supports any text entities except table cells written in a TrueType font).
Since version 1.5 you can insert blank lines (the option "Blank") to the XLS table.
Since version 1.7 you can toggle between the row and column insertion modes for coordinates.
See also the XLS2Curve utility and Click2OO (for OpenOffice Calc).
Click2XLS and many other freeware tools are available on www.cadstudio.cz, other CAD videos on CADstudio's YouTube channel.
ACAD
9.6.2011   67663×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14304:How to generate a report of used blocks including their visibility status in AutoCAD LT?
Tip 14059:Import coordinates from CSV files into Fusion profiles.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Back    All CAD Tips
Categ:
