CAD tip CAD tip # 8311:
Question
BIM applications, including Autodesk Revit, use file formats, which are only upwards compatible - so by default you cannot save ("downgrade") projects to an older version of the given CAD/BIM application.
An alternative way of transferring a substantial part of your project (BIM model) to a previous version of the program is the exchange format IFC (Industry Foundation Classes, specified by IAI). Revit supports both export and import of this format. So instead of saving RVT perform an Export to a .IFC format file in the higher version, and then Import this file in the lower version. See "R" > Export > IFC and "R" > Open > IFC.
Always use the highest version (specification) of the IFC format supported in both versions of the application - e.g. "IFC 2x3" or "IFC 2x2" and set the requested export options (views, segmentation of building elements, etc.) - see "IFC Options".
Remember that part of the project information will not be transferred when using this method.
Revit
8.11.2011    71511×
applies to: Revit ·
Tip 14705:What is the difference between Data Exchange Connector and import/export support for a given CAD/BIM format?
Tip 14661:How to export an IFC model from Autodesk Forma?
Tip 14628:What 3D formats are supported in Autodesk FlexSim?
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14114:How to export 3D Solids from Advance Steel to IFC format?
Back    All CAD Tips
Categ:
Take advantage of orthophotos, point clouds, and design files. Get better quality design changes faster with Pointscene More info
