New CADforum look launched.
Over 1.086.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip CAD tip # 8553:
Question
Since AutoCAD version 2013 you can import Google SketchUp models into AutoCAD 3D geometry. But it is not an internal function, it is a free plug-in application from the Autodesk Apps (formerly: Exchange Apps) store.
Run the Autodesk Apps window using the blue "X" (resp. the shopping cart) icon - Exchange - and select the application "SketchUp Import". Install it. This will add a panel to the ribbon Plug-ins.
From this panel, run the icon "Import SKP File" or enter the command IMPORTSKP. Choose the requested .SKP for import and pick the insertion point. If you need to access directly the 3D DWG entities of the imported geometry, first explode the loaded blocks using EXPLODE. SketchUp materials are also converted - to the folder C:\Users\USERNAME\AppData\Local\Autodesk\AutoCAD 2013 - English\R19.0\enu\SketchUpTexture.
The latest version 3.0 support SketchUp .SKP files in the 2014 to 2018 formats.
Example of an imported model:
SketchUp
Conversion logs are written to the file translate.log
AAD2020ACAD2013ADT2013ACAD
30.3.2012    102510×
Tip 14367:What CAD formats are supported in the free Personal (hobby) license of Autodesk Fusion?
Tip 12348:Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit?
Tip 10319:Conversion of Revit families to FormIt 360 and back (and SKP to RFA).
Tip 10145:How to import SketchUp 2014 (and higher) files into Autodesk 3ds Max?
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Back    All CAD Tips
Categ:
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
