CAD tip CAD tip # 8552:
Question
In some cases you need to perform only a simple operation on your drawing, for which you don't need the graphical display - e.g. for purge operations, saving to another format, switching layers, inserting a block, updating thumbnails, etc. Also many software developer workflows can be completed without graphical interface.
Since AutoCAD 2013 you can run this program also in a fast, simplified version, without the graphical window. But most commands remain functional, you can load applications and drawings, perform non-graphical editing operations. The mail advantage is fast loading and working even on a computer without an appropriate CAD graphics card. This mode is very suitable for running scripts and automatic operations.
You can run the core console version of AutoCAD or AutoCAD LT by the EXE program AcCoreConsole.exe located in the AutoCAD folder:
You can enter AutoCAD commands interactively or specify the particular drawing and script in the runstring. The runstring parameters for running the console are these:
AcCoreConsole.exe [/i {input dwg}] /s {script} [/product {product}] [/l {language}] [/isolate {userid} {userDataFolder}] [/readonly] [/p[rofile] {profile}] [/loadmodule {module}]
AutoCAD commands not supported in the console version are listed in the overview.
See also the tip Complete Purge on a single click.
ACAD2024ACAD2014ACAD2013ACLT
29.3.2012   27744×
this tip shared by ARKANCE experts applies to: AutoCAD 2024 · AutoCAD 2014 · AutoCAD 2013 · AutoCAD LT ·
Tip 15034:How to integrate the PDF markup process in Bluebeam with Revit?
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14753:Overview of startup parameters for acad.exe and acadlt.exe (runstring)
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Back    All CAD Tips
Categ:
