CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] ARKANCE | CONTACT | CAD ESHOP - CZ | SK | EN | DE
Over 1.077.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 9238:
Question
When creating a shaded documentation view on a 3D model (e.g. with the VIEWBASE command) AutoCAD uses the default resolution of 100dpi. If you want to increase the resolution (display precision, smoothness) of your shaded view - to get rid of jagged, stepped edges - set a higher dpi value.
Before you create the doc.view, run the dialog "View standard" (the command VIEWSTD or ribbon Layout > Styles and Standards > dialog arrow) and in the "Shaded view quality" list set 200 or 300 dpi.
Compare two overlaid shaded views on a cylinder solid, with different dpi quality (50/300dpi):
For general 3D viewports in layouts you can use the FACETRES setting to set resolution.
ACAD2014ACAD2013
6.5.2013    18816×
Prices - CAD eShop:
applies to: AutoCAD 2014 · AutoCAD 2013 ·
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 12609:Dynamo - how to convert a raster photo to 3D model in Revit?
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Tip 7424:Converting bitmaps to 3D NURBS surfaces (engraving images).
Categ:
