New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9200:
Question
Standard multilanguage installation of Autodesk 3ds Max 2014 or 3ds Max Design 2014 contains all neccessary files for multiple localizations. The particular language of the user interface can be selected at the application launch - by clicking on an appropriate icon, resp. entering the appropriate parameter in the application runstring - e.g.:
"C:\Program Files\Autodesk\3ds Max Design 2014\3dsmax.exe" /Language=DEU
The installed language versions are preset in the Start menu - English, German, French, Japanese, Korean and Chinese (Simplified Chinese):
max2014
12.4.2013    25299×
applies to: 3ds Max 2014 ·
Tip 14260:How to extract attributes with tag names containing accents?
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13305:Where can I find the icon to run Civil 3D 2023 as AutoCAD?
Tip 13174:Transfer electronic designs from Tinkercad to Fusion 360.
Tip 12524:Overview of Revit runstring parameters (for Revit.exe)
Back    All CAD Tips
Categ:
