  Visitors: 6053
CAD tip CAD tip # 8971:
Linking together values of two dimensions in AutoCAD.
A - answer You have two dimensions and you need to automatically change the second dimension when the first dimension is updated - to the same or to a derived value.
You can use dynamic text fields for such link. Create the first dimension in a usual way, by dimensioning an object. Create the second dimension, double-click on its text to edit it (use DDEDIT in older AutoCAD versions). Delete the original text (the dimension value) and choose Insert > Field from the context ribbon (or press Ctrl+F). In the Field dialog, choose the category Objects, the field Object. Select the the object of the first dimension and from the Properties list choose the property "Measurement". Adjust the Format and Additional format as neccessary and finish editing of the second dimension.
Both dimensions stay dynamically linked - the second one depends on changes of the first one (after regeneration or save).
Text fields can contain also arithmetic expressions (see the tip 9717), so you can also modify the text of the second dimension by a calculation.
ACADLT
15.12.2012    14398×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 14039:How to display the total volume or surface of 3D solids in DWG?
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
Tip 13760:Parametric text content in Fusion 360 sketches (and models).
Tip 13740:Dynamic label with filesize of the current DWG file.
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
