CAD tip CAD tip # 7003:
Question
If you want to insert a text in your drawing (e.g. to the title block) which contains a manipulated name of the current drawing file - e.g. the filename left-trimmed or right-trimmed at a number of characters, you can use a combination of Diesel expressions in an automatic text field (e.g. with the FIELD command).
Some examples:
Drawing file name, no path, from the 3rd character (paste as a Diesel expression to a Diesel-type field):
$(substr,$(getvar,DWGNAME),3,99)
Drawing file name, no path, no extension (4 characters), right-trimmed at another 3 characters (paste as a Diesel expression to a Diesel-type field):
$(substr,$(getvar,DWGNAME),1,$(-,$(strlen,$(getvar,DWGNAME)),7))
Beginning of the drawing path (12 characters), ellipsis, first 8 characters of the drawing file name (paste as a Diesel expression to a Diesel-type field):
$(substr,$(getvar,DWGPREFIX),1,12)...$(substr,$(getvar,DWGNAME),1,8)
Path without the disk letter and the drawing file name, all converted to uppercase (paste as a Diesel expression to a Diesel-type field):
$(upper,$(substr,$(getvar,DWGPREFIX),3)$(getvar,DWGNAME))
ACADACLTADT
19.10.2009   37415×
this tip shared by ARKANCE experts applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture ·
Tip 14957:Controlling Navisworks from the runstring.
Tip 14805:Some useful Unicode characters for your technical drawings.
Tip 14803:Superscripts, subscripts, fractions, and tabs in Inventor text.
Tip 14714:Why is Fusion suddenly putting apostrophes in my text?
Tip 14681:How to quickly convert XLS tables to CSV format without opening Excel?
Back    All CAD Tips
Categ:
