CAD tip # 7005:
Tip 13887: | ClosestPt - the nearest point on another curve |
Tip 13864: | Displaying the curvature comb or radii of a general curve - CurvComb. |
Tip 13426: | Use of alternative units for arithmetic in dimensions (without square brackets). |
Tip 13333: | "Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts. |
Tip 13040: | iLogic - display information about complexity of an Inventor part. |
How to add thousands separators in AutoCAD numbers?
AutoCAD reports SELECTSIMILAR as an unknown command. « | » Modified drawing name as an automatic field.
