CAD tip # 6785:
Tip 13948: | Undocumented function for quick block attribute editing - directly edit an attribute. |
Tip 13868: | XrefStamp - create a dynamic list of xrefs in your DWG drawing. |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13831: | ReplMTcol - recoloring parts of text in paragraph Mtext. |
Tip 13784: | Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT? |
How to import a PDF file into AutoCAD? « | » How to divide a closed area to a number of subdivisions?
