  Visitors: 8883
CAD tip CAD tip # 10097:
Multiple applications with the same name in the "Open with" menu - which to choose?
A - answer When you open a CAD file (DWG, RVT, RFA, etc.) using the context menu, Windows offers multiple applications with the same name - e.g. different types of AutoCAD, different versions of Revit you have installed, etc. How to choose the right program version you want to run?
If you want to assign a fixed version of the launched application for the given file type (e.g. for RFA - Revit Family), assign the proper program in the Registry key - e.g.:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Revit.Family\shell\open\command
If you need to dynamically choose which version to run, rename the listed applications to more descriptive names. E.g. change the menu list:
Which app to launch?
To a better:
You can make it by adding the version number or other identification by changing the Registry key:
HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache
E.g. for the above illustrated modification:
EXE programs to start
Similarly you will also update the following dialog type:
Revits to open with
You can use this method also to assign office applications and file types, pictures, videos and other document types.
ACADLTRevitInvNWDWG
14.11.2014    9116×
applies to: AutoCAD · AutoCAD LT · Revit · Inventor · Navisworks · DWG ·
Tip 11145:AutoCAD: Customization file load failed.
Tip 10658:How to open a R/O DWG without the read-only warning?
Tip 10552:Which Revit version will open a RVT file on double-click?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 9937:Preset displaying of thread features in Inventor 2015 drawing views.
