CAD tip # 10552:
applies to: Revit · |
Tip 13800: | Visually compare 3D geometry in CAD and BIM files. |
Tip 13227: | Reference Explorer - quick analysis of your project or assembly (file size, xref errors). |
Tip 12524: | Overview of Revit runstring parameters (for Revit.exe) |
Tip 12184: | Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD). |
What for is a .DSD file in AutoCAD.
AutoCAD 2015 and 2016 do not allow to select paper size for Designjet T120/T520. « | » Why is my STL file imported into Inventor 10x smaller?
