Over 1.124.000 registered users (EN+CZ).
CAD tip # 7428:
Question
If your drawing doesn't display block attributes (even standard attributes not marked as "invisible"), check the setting of the ATTDISP command.
This command offers the following options:
- Normal - restores the standard attribute visibility: visible attributes are displayed, invisible ones are hidden
- On - all attributes will be visible (also the attributes marked as "invisible")
- Off - sets all attributes as invisible, hidden (even the standard "visible" attributes)
ACADACLTADT
28.6.2010
20141×
