CAD tip CAD tip # 7426:
Question
You are trying to use the command "Import AutoCAD block" (Annotate > Symbols) in your Inventor drawing environment and this function (icon) is grayed out?
The funtion of importing a specific external block from a different DWG file is active only in Inventor drawing views using the DWG format (not the IDW). Create a drawing based on the Standard.dwg template - then you will be able to import AutoCAD blocks.
Inventor2011
27.6.2010   11794×
this tip shared by ARKANCE experts applies to: Inventor 2011 ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Back    All CAD Tips
Categ:
