New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 7758:
Question
While in a command you can manually override your Object Snaps. All you have to do is enter a code below while the command (prompt) is active:
  • END = Endpoint
  • MID = Midpoint
  • CEN = Center
  • NOD = Node
  • QUA = Quadrant
  • INT = Intersection
  • EXT = Extension
  • INS = Insertion
  • PER = Perpendicular
  • TAN = Tangent
  • NEA = Nearest
  • APP = Apparent intersection
  • PAR = Parallel
  • M2P = Mid between 2 points
  • NON = NONE
Credit: Robert Williams
ACADLT
26.1.2011    9483×
applies to: AutoCAD · AutoCAD LT ·
Tip 13887:ClosestPt - the nearest point on another curve
Tip 13668:How to create a sphere from 4 points in AutoCAD?
Tip 13653:FPoly - draw fixed-length polylines in AutoCAD.
Tip 13587:Dynamic label of 3D coordinates.
Tip 13495:How to create a full diameter dimension with two arrows?
Back    All CAD Tips
Categ:
