Over 1.095.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 7757:
Question
AutoCAD 2011, 2012 and 2013 (and Map and Civil 3D) supports max. 2 billion points in point clouds. From these 2 billions, only 1.5 bln points can be displayed at the same time in a single drawing (even with multiple clouds attached).
Typical LiDAR jobs contain millions up to hundreds millions points.
Since versions 2014, Autodesk products use the ReCap technology which is not limited in number of points and easily manages point clouds with more than 20 billion points.
ACAD2013ACAD2012ACAD2011ADTCivilMap
26.1.2011
12058×
applies to: AutoCAD 2013 · AutoCAD 2012 · AutoCAD 2011 · AutoCAD Architecture · Civil 3D · AutoCAD Map 3D ·
