New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7505:
Question
Using the Windows print driver "DWF Writer" you can generate files in the CAD publishing format DWF and DWFx from any Windows application.
The free "pseudo-printer" driver Autodesk DWF Writer for Windows 2000, WinXP, Vista and Windows 7 (in 32-bit or 64-bit version) can be downloaded from Download.
The 2D DWF print settings allow to set resolution (dpi), color depth, output media format, file location and other parameters for writing out the DWF file. You can also directly display the resulting .dwf or .dwfx file in the free Autodesk Design Review viewer.
DWF print parameters - Vista 64
Please use the internal, native functions to publish DWF files from Autodesk software - these functions provide wider options and higher quality of the output.
DWF
18.8.2010    16815×
applies to: DWF/Design Review ·
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 8074:Displaying 3D CAD model on a mobile phone or tablet (mobile viewer).
Tip 6074:DWFx - viewing CAD data without any viewer.
Tip 4678:Publish 3D DWF files from CAD applications.
Tip 4614:How to publish DWF from SolidWorks, Pro/ENGINEER, SolidEdge or CATIA?
Back    All CAD Tips
Categ:
