New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 8157:
Question
You can add a text in your drawing which will automatically reflect the contents of a given environment variable on your PC.
Just add a text (e.g. by DTEXT) with the contents:
%<\AcDiesel $(getenv,TEMP)>%
(you can replace "TEMP" by the name of any other environment variable)
The contents of this dynamic field is updated on regen. Non-existing variables will display "----". You can add such text field also to a block attribute.
ACADLT
21.8.2011    6788×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 14339:Time tracker for Autodesk Inventor - how much time have I spend on a design?
Tip 14307:How do I generate EDU licenses for the Autodesk license server?
Tip 14271:How to use the STRETCH command to resize an object to a specific size?
Tip 14215:IF statement in AutoCAD text fields and attributes.
Tip 14192:MLfillet - how to fillet multilines in AutoCAD?
Back    All CAD Tips
Categ:
