CAD tip # 7661:
applies to: AutoCAD · |
Tip 13948: | Undocumented function for quick block attribute editing - directly edit an attribute. |
Tip 13868: | XrefStamp - create a dynamic list of xrefs in your DWG drawing. |
Tip 13855: | DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder. |
Tip 13831: | ReplMTcol - recoloring parts of text in paragraph Mtext. |
Tip 13784: | Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT? |
Enumeration lists for Inventor parameters. « | » Extract hatch patterns to PAT files - copy hatches between DWGs.
Featuring: DwgTextTranslator translates a series of drawings from one language to another using MS Access. Download a fully functional trial version. |
