CAD tip CAD tip # 8244:
Question
Printed drawings from Revit are not scaled properly, differences from true dimensions in the given scale are off by tens of percents.
This is usually caused by setting an improper plot scale in Revit.
In the Print dialog click on the button Settings and in the dialog "Print settings" change the option "Fit to page" to "Zoom 100%" - e.g. printing precisely 1:1, without scaling up or down.
Print 1:1 from Revit (CZ version)
Revit
30.9.2011   17335×
this tip shared by ARKANCE experts applies to: Revit ·
Tip 14958:A PDF drawing from Revit or AutoCAD does not print exactly at a 1:1 scale.
Tip 4440:HP Instant Printing from Autodesk DWF Viewer / Composer.
Back    All CAD Tips
Categ:
