New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 11729:
Question
When working with annotation scales, you may need to select all objects in your DWG drawing, which have assigned a specific scale.
Exactly this can be done with the simple application SelByAnnoScale. Download it from Download, load it by dragging the LSP file to your AutoCAD window or with APPLOAD and type the command SelByAnnoScale.
After you specify the searched scale (e.g. "1:10"), this function selects all block references, hatches, texts, leaders, dimensions, tolerances and attribute definitions, which have your specified scale assigned. The objects remain highlighted and grip-selected, or you can use them as the selection set "P" in a subsequent AutoCAD editing command.
ACAD
13.12.2017
25021×
applies to: AutoCAD ·
