CAD tip CAD tip # 6692:
Question
XLS2Curve If you need to import a list of coordinates from Excel, generate blocks at computed coordinates, or draw a mathematic curve computed with Excel expressions, you may need the CADstudio Xls2Curve utility.
This tool imports coordinates (XY or XYZ) from a previously selected region in an opened (active) Excel sheet. From these 2D or 3D coordinates, it then creates points (Point), curves (LWPolyline, 3DPolyline), splines or block references (Insert) in your drawing. In the Excel table just mouse-select any contiguous range containing the point coordinates.
An example of import of the results from a mathematic expression describing a lemniscate curve (see the attached XLS sample):
List of coordinates X-Y in Excel
Imported spline curve in AutoCAD
Included is the complementary function Curve2Xls which exports coordinates (XY or XYZ) of curves and points to Excel (the selected cell of the running Excel sheet).
You can download the Xls2Curve utility at DL Download. The activation of this trial version (limited to 10 points) can be done with the XANADUREG command.
ACADADTMapCivil
25.5.2009   62892×
this tip shared by ARKANCE experts applies to: ACAD · ADT · Map · Civil ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14613:How to set the elevation of objects according to the value of Object Data, OD? (OD2Z)
Back    All CAD Tips
Categ:
