CAD tip # 13793:
applies to: Inventor · |
Tip 13997: | 4 methods of 3D orbit in Inventor, with specified pivot. |
Tip 13641: | How do I restore an accidentally deleted file in Fusion 360? |
Tip 12365: | How to show color print (sketch) also on the sheetmetal flat pattern? |
Tip 12201: | Quick dynamic measuring of objects near your cursor. |
Tip 12118: | Easy frames and tables in Revit text annotations. An undocumented trick. |
3D offset of a surface.
PCF file generated from AutoCAD Plant 3D is not compatible with my application. « | » Part number from the Frame Generator is not transferred to the Part Number iProperty.
