Over 1.115.000 registered users (EN+CZ).
CAD tip # 8187:
Question
If you want to switch off (disable) selection preview highlighting when you move cursor over objects in you DWG drawing, set the variable SELECTIONPREVIEW to 0 or 2.
You can also change this setting in the Options dialog, in the Selection tab, section "Selection preview" and the button "Visual effects".
Note: SELECTIONPREVIEW influences also other commands, e.g. the FILLET previews.
ACAD
2.9.2011
26824×
this tip shared by ARKANCE experts applies to: AutoCAD ·
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](../common/arkance_186.png)
