CAD tip # 6987:
Tip 11757: | How to change blocks properties ex-post: annotative, allow exploding, scale uniformly |
Tip 8998: | How to make saving to older versions of DWG (SAVEAS) faster? |
Tip 6111: | Very slow Xrefs, block insertions, copying objects; bloated files. |
Tip 5871: | How to batch-remove excessive annotation scale lists in DWGs? |
Tip 3649: | Shorter DWGs - I have a multi-megabyte drawing with 'almost nothing' drawn in it. |
What is the "orphaned" status at Xref?
The action recorder macro changes my drawing view. « | » Startup error: Revit could not load RevitMFC.dll
Featuring: Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally. Try Excellink 2015 |
