After the installation of Microsoft Office 365 (or after another modification in Windows) the VBA module and macros may stop working. The local VBA 7 module is neccessary for proper operation of Inventor 2014/2015 and for add-on applications in AutoCAD 2014/2015 (if its VBA Object Enabler was installed previously).
To re-enable the VBA module, take you your CAD installation media or deployment image and reinstall the module:
3rdParty\x86\VBA\Vba7.MSI (32-bit)
resp.
3rdParty\x64\VBA\Vba7.MSI (64-bit)
(you may need to install the English version of VBA, i.e. VBA71033.msi for some CAD localizations)
or reinstall the AutoCAD VBA Object Enabler (see Download).
Featuring: Use Google Earth images in your AutoCAD projects with the Plex.Earth Tools
