Over 1.091.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7565:
Question
The layer "$AUDIT-BAD-LAYER" is created during the drawing diagnostics process - the AUDIT command. This layer contains objects that were incorrectly placed in a wrong layer.
Typically, this situation occurs when some objects were drawn in the dimension control points definition layer - DEFPOINTS.
Erase the objects from the DEFPOINTS layer, perform PURGE, Save & Close and reopen the drawing. Now repeat the AUDIT - the AUDIT-BAD-LAYER should not reappear.
ACADACLTADT
20.9.2010    29849×
Tip 14477:PurgeAll - automation of DWG file cleaning
Tip 11469:Why you should not use the DEFPOINTS layer to draw geometry?
Tip 10820:Unable to save to drawing c:\folder\filename.dxf
Tip 10612:Revit error: Unable to open because of unresolved pointer references​
Tip 9276:AutoCAD reports some xrefs as "Unresolved".
Back    All CAD Tips
Categ:
