  Visitors: 5920
CAD tip CAD tip # 9757:
How to remove the EDU stamp "Created in an educational version" from a DWG drawing file?
A - answer Educational versions (licenses) of AutoCAD releases older than 2014 SP1 stored a permanent information about using an educational version inside the saved DWG files. This identification was part of the license protection scheme -- licenses of the discounted or free educational and student versions of AutoCAD do not allow to use this software for commercial projects.
This limitation for using student and educational (school) versions for commercial work still applies. But you can now remove the visible portion of the information - the banner "CREATED IN AN EDUCATIONAL VERSION", which was displayed on plotted/printed drawings and when opening/inserting "edu" DWG files in standard commercial versions of AutoCAD.
This information can be now easily removed by opening the drawing in AutoCAD 2015 (or in LT 2015, or evt. also in TrueView 2015) and higher, and by just saving the respective DWG file (Ctrl+S).
Make sure that your AutoCAD usage is compliant with your licence terms.
ACAD2015ACADLTDWG
29.3.2014    37717×   FAQ
Prices - CAD eShop:
applies to: AutoCAD 2015 · AutoCAD · AutoCAD LT · DWG ·
Tip 13844:With which subscriptions do I get Autodesk Drive cloud storage as a bonus?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13192:Why I cannot see the "My Insights" tips and hints in AutoCAD?
Tip 12749:Generate parametric mathematical 3D surfaces (meshes) in Fusion 360.
Tip 11727:Animated drawing of a curve shape in AutoCAD.
