  Visitors: 6104
CAD tip CAD tip # 13683:
Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
A - answer Starting with AutoCAD LT 2024 (and 2025 and higher), it is possible to run LISP applications, commands and files in .LSP, .FAS or .VLX (and .DCL) format in AutoCAD LT. However, LT version has some limitations compared to full AutoCAD in LISP support. Most of the existing LISP applications will work without any problems, but some may end with an error or fail to produce the expected result. Besides the LISP API, AutoCAD LT now supports also the Javascript API.
Thus, of all the Arkance Systems (CAD Studio) LISP applications - see Download - most will also work, but some (e.g. Click2XLS, DTM, SureSave...) will have the limitations mentioned below. None of these applications will offer the new version notification in LT.
Limitations
The first type of limitation is the lack of support for external ActiveX objects. For them you cannot use the (vlax-create-object), (vlax-get-object), (vlax-get-or-create-object), (vlax-import-type-library), (vla-GetInterfaceObject) functions. These functions are typically used for online communication, clipboard handling, XML, binary files, Excel, Word, Access (or other database tools), etc. But there may be a workaround for your situation - see the Tip 14007.
E.g the call:
(vlax-create-object "Microsoft.XMLHTTP")
returns nil and the web "communicator" object is not created.
Another, quite logical limitation is working with 3D DWG objects (plus render tools, databases...). These are not supported in LT version and therefore you cannot use (command) to call unsupported commands (or access variables), nor can you create or modify 3D objects via (entmake), (entmakex), (entmod).
E.g. the construction:
(entmake (list (cons 0 "3DFACE")(cons 10 (car triangle))(cons 11 (cadr triangle))(cons 12 (caddr triangle))(cons 13 (caddr triangle))))
returns nil and the entity of type 3DFACE is not created (silent fail, no error is reported).
You cannot access XRecords, used by some LISP applications to store data in dictionaries.
You also can't use Express Tools commands or its libraries or "acet-" functions in LT. Of course, you can't call VBA or ARX or .NET functions either.
Automatic loading of LISP functions from ACADDOC.LSP must be done in the LT version in the ACADLTDOC.LSP file. Also, .MNL files (with CUIx menu files) are not automatically loaded. The LT version does not work with profiles. And there is no AI_UTILS.LSP preinstalled.
Note that the LT version does not have a LISP editor (IDE, the VLIDE command) and therefore no debugger or compiler or linker. You can switch Unicode support though - LISPSYS. You cannot use (vlisp-compile) to compile LSP files either.
You can use the .bundle autoload mechanism in LT (the folder Autodesk/ApplicationPlugins). Don't forget to add Platform="ACADLT" to the RuntimeRequirements section in your PackageContents.xml file.
The AutoCAD LT 2024 for Mac version has no LISP. And AutoCAD for Mac has other limitations - e.g. you cannot use ActiveX functions (vlax-), reactors, etc.
ACLT2025ACLT2024
1.4.2023    45391×   FAQ
Prices - CAD eShop:
applies to: AutoCAD LT 2025 · AutoCAD LT 2024 ·
Tip 14085:JavaScript API support in AutoCAD and AutoCAD LT.
Tip 14048:List of disks, CD-ROM drives, USBs and other disk functions for LISP.
Tip 14007:Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.)
Tip 14006:Universal MsgBox in AutoLISP.
Tip 13977:How to publish a PDF to the same folder as a DWG drawing in AutoCAD?
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
