  Visitors: 8669
CAD tip CAD tip # 7042:
List of inspection dimensions in the Inventor drawing.
A - answer If you need a list (table) of inspection dimensions from your Inventor 2010-2016 drawing, you can export it using the ListInspection macro.
The ListInspection macro will make a list of all inspection dimensions in the current Inventor drawing (IDW/DWG), including tolerances. The precision of dimension values is the same as in the drawing. The list is exported to a TAB delimited file. Its file name is the same as the file name of your drawing with just the ".txt" extension added. Both metric and imperial dimensions are supported.
In the drawing environment use Alt+F11 to start the VBA editor. Use "File > Load project" to load the ListInspection.ivb file. Switch back to your Inventor drawing and press Alt+F8 to display macros. Pick ListInspection.Report and click the Run button.
You can drag the resulting TXT file to Excel.
The frame/shape codes are "No", "Ang" or "Rnd".
Sample output:
DimValue Toler-L Toler-H InspLabel                  Shape    Rate  Hole
3.235    -0.2    0.3     myLabel1                   Rnd      A1
2.854    0       0       myLabel2                   Rnd	           H7
0.635    0       0       myDesc <StyleOverride Font='AIGDT'>m</StyleOverride>  Ang R
You can download ListInspection from Download
Inv2014Inv2012Inv2011Inv2010
6.11.2009    20941×
Prices - CAD eShop:
Tip 13611:BOM with multi-line items in Inventor.
Tip 12828:How to quickly delete 3rd party links to external objects in Inventor?
Tip 12815:How to fill iProperties into Inventor files from Excel?
Tip 12520:How to set Inventor Display style and Lighting style from an iLogic macro?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
