Autodesk Inventor Professional 2025 supports import and export of a wide range of CAD and BIM formats.
In addition to Inventor's own, native data formats, version 2025 includes built-in translators (converters) for the following "foreign" and neutral CAD formats and format versions (file import/export, plus associative references of AnyCAD models, new features compared to version 2024 are highlighted):
Format | Import | Asoc. AnyCAD | Export |
Inventor 2024/2026 (*.ipt, *.iam) | older and newer | + | - |
AutoCAD 2D/3D (*.dwg, *.dxf) | R12 - 2018 | + | 2000 - 2018, ACM 2023 |
Alias (*.wire) | version 2023, 10 (11) | + | - |
CATIA V4 (*.CATPart, *.CATProduct, *.model) | all versions | - | - |
CATIA V5 (*.CATPart, *.CATProduct) | R6 - V5-6R2023, .cgr R9 and newer | + | R10 - V5-6R2023 |
Creo Parametric (*.prt, *.asm) | Creo Parametric 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0 | + | + |
Fusion 360 (*.fusiondesign) | all versions | + | - |
GLTF (*.gltf,*.glb) | - | - | all (incl.textures), V2.0 |
IDF (*.idf) | 2.0, 3.0 | - | - |
IFC (*.ifc) | IFC2x3; IFC4; IFC 4.3 | - | IFC 2x3 |
IGES (*.igs) | all versions | - | 5.3 |
JT Precise (*.jt) | 7.0 - 10.8 | - | 8.0 - 10.8 (except 6.4,7.0,8.3, incl.PMI) |
NX (*.prt) | Unigraphics V13 až Siemens NX 12, NX 1847; 1872; 1899; 1926; 1953; 1980; 2007; 2206; 2212; 2306 | + | - |
OBJ mesh (*.obj) | all | - | all |
Parasolid (*.x_b, *.x_t) | up to version 36.0 | - | 9.0 - 36.0 |
Point-cloud | .rcs (+ formats z ReCap) | - | - |
Pro/ENGINEER (*.prt, *.asm) | up to version Wildfire 5.0 | + | - |
Pro/ENGINEER Granite (*.g) | up to version 16.0 | - | 9.0 - 16.0 |
Pro/ENGINEER Neutral (*.neu) | all | - | all |
QIF (*.qif) | - | - | 3.0 |
Revit (*.rvt, *.rfa) | .rvt up to 2025 | + | .rfa and .rvt 2023,2024,2025 |
Rhino (*.3dm) | 1.0 - 7.0 | - | - |
SAT (*.sat) | 4.0 - 7.0 | - | 7.0 |
Solid Edge (*.asm, *.par, *.psm) | V18–V20, ST1–ST10, 2019-2023 | + | - |
SolidWorks (*.prt, *.sldprt, *.asm, *.sldasm) | 2001 Plus - 2023 | + | - |
STEP (*.stp, *.ste, *.stpz) | AP214, AP203E2, AP242 (ISO 10303-21) | + | AP214, AP203E2, AP242 |
USD (*.usdz) | - | - | all |
SMT (*.smt) | up to version ASM230 | - | ASM230 |
STL (*.stl) | all | - | all |
DWF (*.dwf, *.dwfx) | 6.0 – 7.5 | - | 7.5 |
3D PDF (*.pdf) | - | - | 1.6 |
Support for higher versions of foreign formats may require updates to Inventor, such as version 2025.1 and 2025.2.
Support for Autodesk Fusion requires the Desktop Connector component and data stored in Fusion Team.
Other formats are available in the form of add-on translators (e.g. VRML - .wrl; GEO - .geo; SVG - .svg).
See also CAD formats. See also the format support in version 2020.
Inventor2025
* CAD
1.4.2024
2100×
