CAD tip # 31:
Tip 14080: | AutoCAD 2025 is not displaying some fonts correctly. |
Tip 13426: | Use of alternative units for arithmetic in dimensions (without square brackets). |
Tip 11794: | Undocumented code in field expression - MText contents without control characters. |
Tip 11160: | Dynamic display of layer/block/text style/linetype properties. |
Tip 11128: | How to convert lines forming a text to a text entity. |
After creating of new Profile, EN commands (_line e.g.) in old profile cause crash of AutoCAD. « | » DXF in R12 format saved from A2000 does not explode MTEXT to TEXT (unlike R14)
