  Visitors: 5614
CAD tip CAD tip # 12059:
Setting the G0, G1, G2 continuity of lofting.
A - answer In the parameters of the LOFT command you can specify the level (order) of continuity, smoothness between profiles of the new surface or solid body.
After you specify the source profiles, use the Settings option and in the dialog "Loft Settings" set the continuity for Smooth fit (LOFTNORMALS).
Subsequently you can adjust the continuity and bulge values on the resulting object through different types of grips - see the different continuity settings on the lofted objects (the same combination of an ellipse + point):
ACAD
10.11.2018    8423×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13433:How to create a parametric dynamic 3D block in AutoCAD?
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 7800:How to model a 3D hyperboloid?
Tip 7267:How to make a 3D solid from a series of profile outlines?
Tip 2231:How to read a coordinate list into Inventor (sketch)?
