Not only from AutoCAD and Revit, but now also from the CAD/CAM application Autodesk Fusion 360 you can directly use the cloud rendering service available in the Autodesk 360 cloud. So you can create photorealistic renders of large models without any performance- and time-demands on your workstation.
The procedures of invoking the cloud render, choosing the size (resolution) of the output image or animation and its influence on consumption of cloud credits, the progress of rendering and downloading the resulting files are illustrated in the video on CAD Studio's YouTube channel:
You can achieve similar results also by manual uploading of an AutoCAD, Revit, 3ds Max, Navisworks or Fusion 360 file on the cloud rendering service URL - i.e. rendering.360.autodesk.com.
Similarly, the resulting images, animations and turntables rendered from the Fusion 360 environment will automatically appear in your private gallery on rendering.360.autodesk.com/mygallery.
Many samples of 3D models and their rendered output from Fusion 360 can be found in the public gallery on fusion360.autodesk.com.
Featuring: Extend your AutoCAD LT productivity with our popular add-on CADstudio LT Extension
