CAD tip # 11113:
applies to: Inventor 2017 · |
Tip 13800: | Visually compare 3D geometry in CAD and BIM files. |
Tip 12600: | Parametric 3D curves in Fusion 360. |
Tip 12297: | Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility? |
Tip 12184: | Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD). |
AutoCAD 2013 command line is off-screen.
How to insert framed (boxed) text into Inventor drawings? « | » Inventor drawing diplays flipped, mirrored (as from underside)
Featuring: Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally. Try Excellink 2015 |
