New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 7318:
Question
As you approach to the point when the trial (unactivated) AutoCAD license expires (30 days between the installation and activation of your license), it may be neccessary to activate your license "on the fly", inside a running AutoCAD session (not on the AutoCAD launch).
You can perform the activation with the ABOUT command. Click the buttons About the product > Activate and you'll get to the dialog "Autodesk Licensing", which is usually displayed on AutoCAD startup:
Click the Activate button in this dialog. If you have received your activation code over e-mail, pick the option I have the activation code from Autodesk and in the numbered fields 1-16 enter the hexadecimal activation code from the e-mail. It is not neccessary to manually type-in the individual fields - just copy/paste the code as a single string (some fields may remain blank). By finishing the activation you will get back to your running AutoCAD session.
ACAD2011ADT2011ACADM2011Civil2011ACAD2010
*CAD
21.4.2010
64753×
applies to: AutoCAD 2011 · AutoCAD Architecture 2011 · AutoCAD Mechanical 2011 · Civil 3D 2011 · AutoCAD 2010 ·
