Over 1.121.000 registered users (EN+CZ).
CAD tip # 7319:
Question
3ds Max 2011 offers two types of import of DWG files (M > Import > Import > Formats) - the new "AutoCAD Drawing" and the old "Legacy AutoCAD". The new type is preferred in most situations. What are the differences?
Supported only in the new "AutoCAD Drawing" mode:
- Support for AutoCAD, AutoCAD Architecture and Revit Sun and Shadows information.
- Support for AutoCAD Architecture mapped UV textures on objects.
- Support of multiple materials on ACIS solids in files from Revit Architecture 2008 and AutoCAD Architecture (ADT) 2007 and later.
- Support for all ObjectARX custom objects (ignored by the Legacy importer).
- Specialized support for AutoCAD Architecture and Revit objects, including style/component grouping and naming, style associations for material and modifier propagation, and material translation and assignment.
- Specialized support for AEC Civil contour objects (translated into a Terrain object).
- Support for Raster objects.
- Support for axonometric named views (translated into cameras with the Orthogonal toggle turned on).
- Support for attached drawing xrefs.
- Support for DXF files.
- Rescaling to imported drawings created with units that differ from the 3ds Max system units.
- Ability to skip frozen layers, or to select specific layers to import (or exclude) from a list. Maintaining layer assignments from the drawing file.
- Ability to set shape rendering parameters before importing to 3ds Max.
Supported only in the old "Legacy DWG Import" mode:
- AutoCAD primitives translated into 3ds Max primitives.
- Support for Text (not MText).
- Imported blocks are represented as groups.
max2011DWG
23.4.2010
31813×
this tip shared by ARKANCE experts applies to: 3ds Max 2011 · DWG ·
