CAD tip CAD tip # 7923:
Question
If you need to align a series of linear dimensions to a single line, you can use the command DIMSPACE available in AutoCAD since version 2008.
Select the first (default) dimension and then the other dimensions which will be aligned. On the "space" (offset) prompt enter 0.
DIMSPACE
ACAD2012ACAD2010ACAD2008
18.4.2011   28282×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD 2010 · AutoCAD 2008 ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14907:Why are the hole center marks in Inventor not aligned to the center of a circular part?
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 13495:How to create a full diameter dimension with two arrows?
Back    All CAD Tips
Categ:
