CAD tip CAD tip # 7953:
Question
Instead of the PAPER/MODEL button (in the bottom AutoCAD status bar) and instead of mouse-double-clicking, you can also switch the paperspace and model with a keyboard shortcut.
There is no predefined AutoCAD keyboard shortcut for this, but you can add your own.
Start the CUI editor and use the "star with an asterisk" button to add a new command. Name it e.g. "PaperModel" and use the following DIESEL command as its macro:
^C^C^P$M=$(if,$(=,$(getvar,cvport),1),._mspace,._pspace);
Now go to the CUI section Keyboard shortcuts > Shortcut keys and mouse-drag here your PaperModel command from the command list. On the right in the Properties > Access > Hotkey, assign the requested shortcut to this command, e.g. Ctrl+Alt+P. Finish the CUI dialog.
Now you can toggle model/paper spaces in your layouts just by pressing Ctrl+Alt+P.
In older AutoCAD versions you can add the shortcut in the section ACCELERATORS in your .MNU file
ACADACLTADTMapCivil
4.5.2011   26023×
this tip shared by ARKANCE experts applies to: ACAD · ACLT · ADT · Map · Civil ·
Tip 15073:How to run an iLogic rule from the ribbon or with a keyboard shortcut?
Tip 14846:Do you know how to set camera FOV in Fusion's perspective view?
Tip 14815:Dynamic switching of the Fusion color theme according to Windows.
Tip 14782:Command line in Autodesk Fusion.
Tip 14772:Keyboard shortcuts in Autodesk Forma Site Design.
Back    All CAD Tips
Categ:
