New CADforum look launched.
Over 1.082.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip CAD tip # 9309:
Question
With the free utility CADstudio SaveOrig you can save a DWG drawing automatically in that format, in which it was loaded into AutoCAD. So if you e.g. open a 2007-version DWG drawing in AutoCAD 2014, edit it and then save it with the SAVEORIG command, the resulting file will be again in the DWG2007 format - automatically, without manual selection of the proper setting in SaveAs.
The application checks non-saveable versions (e.g. R12), or still unnamed new drawings. You can map this command to the keybord shortcut Ctrl+S.
Load the Saveorig.vlx file downloaded from Download using APPLOAD (or drag it to the "briefcase" to load it in any drawing) and run it by entering "SAVEORIG".
ACAD
20.6.2013    6608×
applies to: AutoCAD ·
Tip 13234:How to place a GeoTIFF image automatically into the correct position?
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
Tip 10487:How to save a DWG/DXF in older format from AutoCAD 360?
Tip 6922:Product codes (registry) of Autodesk CAD applications.
Back    All CAD Tips
Categ:
