  Visitors: 4543
CAD tip CAD tip # 9147:
Batch publishing to PDF uses different margins than single prints.
A - answer Batch plotting (the command PUBLISH) of all layouts (drawings) uses very wide page margins in the resulting PDF file - the plotouts are unusable. Individual, single plots are OK. You are using Acrobat.
The cause is probably that you select the "Adobe PDF" printer for your single plots. But for publishing, you select the "Publish to:" option set to "PDF":
But this option makes use of the AutoCAD printer driver named "DWG to PDF.pc3" - it may have different margins defined from the margins set in your Adobe PDF printer driver.
So either set the "Adobe PDF" printer as the default in all layout sheets and then choose the option "Plotter Named in Page Setup" for publishing, or change the page size and margins in the printer driver "DWG to PDF.pc3" (see e.g. C:\Users\*username*\AppData\Roaming\Autodesk\AutoCAD 2013\R19.0\enu\Plotters).
We recommend to always use the printer "DWG to PDF.pc3" for printing to PDF from AutoCAD - this internal printer allows to embed layers into the PDF (usually cannot be done with external printers) and avoids frequent problems with drawing orientation on a sheet.
ACADLTADTCivilACADMMapDWG
15.3.2013    38150×
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 10182:How to create a PDF file from DWG without AutoCAD?
Tip 9348:How to add custom paper format to AutoCAD? (grayed)
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
