CAD tip CAD tip # 7515:
Question
Autodesk Inventor 2011 includes internal translators for the following foreign and neutral CAD file formats and format versions (file import/export):
FormátImportExport
AutoCAD 2D/3D (*.dwg, *.dxf)R12-2011R12-2011
Alias (*.wire)all versions-
CATIA V4 (*.CATPart, *.CATProduct, *.model)all versions-
CATIA V5 (*.CATPart, *.CATProduct)R6-R18R10-R18
IGES (*.igs)all versions5.3
JT Precise (*.jt)7.0, 8.0, 8.1, 8.2, 9.0, 9.1, 9.2, 9.3. 9.47.0, 8.0, 8.1, 8.2, 9.0, 9.1, 9.2, 9.3, 9.4
NX (*.prt)3-6 (7 in SAP)-
Parasolid (*.x_b, *.x_t)up to ver 22.09.0-22.0
Pro/ENGINEER (*.prt, *.asm)up to ver 5.0-
Pro/ENGINEER Granite (*.g)up to ver 6.01.0-6.0
Pro/ENGINEER Neutral (*.neu) allall
SAT (*.sat)4.0-7.04.0-7.0
SolidWorks (*.prt, *.sldprt, *.asm, *.sldasm)2003-2010-
Rhino (*.3dm)(in SAP)-
STEP (*.stp, *.ste)AP214, AP203E2AP214, AP203E2
STL (*.stl)-all
XGL/ZGL (*.xgl/*.zgl)-all
Other formats are available as add-on translators (e.g. VRML - .wrl, Rhinoceros - .3dm).
Inventor2011
21.8.2010   17452×
this tip shared by ARKANCE experts applies to: Inventor 2011 ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 14953:Importing ECLASS files into AutoCAD Electrical.
Tip 14833:CAD formats supported in Autodesk VRED 2026.
Tip 14803:Superscripts, subscripts, fractions, and tabs in Inventor text.
Tip 14799:7 quick methods to upload your project to Autodesk Docs (Forma Data Management)
Back    All CAD Tips
Categ:
