CAD tip # 8269:
Question
If you use FILLET to join a plain Line to an existing Polyline with varying widths of its segments, the resulting new segment takes over the global polyline width - in the version 2011.
In the version 2012, this process keeps the null width of the newly attached segment. If you need to maintain the older behaviour, use the more suitable command JOIN - this command will join both lines in the old way.
ACAD2012ACLT2012
17.10.2011
13424×
this tip shared by ARKANCE experts applies to: AutoCAD 2012 · AutoCAD LT 2012 ·
