CAD tip CAD tip # 8271:
Question
Autodesk Inventor assembly drawings often contains references to iProperties and physical properties of the model (parts). But the "mass" property may be not always updated and the printed drawing may contain inaccurate assembly mass information.
The following VBA macro ensures that printing is invoked after the mass properties are updated:
Sub PrintWithUpdateMass() 'Update mass in all referenced documents Dim drw As DrawingDocument Set drw = ThisApplication.ActiveDocument Dim doc As Document Dim mass As Double For Each doc In drw.AllReferencedDocuments mass = doc.ComponentDefinition.MassProperties.mass Next Call drw.Update 'Invoke print or other command Call ThisApplication.CommandManager.ControlDefinitions("AppFilePrintCmd").Execute End Sub
No error checking included for simplicity
You can assign this macro to a new "Print" icon on your ribbon - see the Tip 8267.
Inventor2012
18.10.2011   22220×
this tip shared by ARKANCE experts applies to: Inventor 2012 ·
Tip 15014:Why doesn't AutoCAD display the Length, Width, and Height properties of a 3D box?
Tip 14980:How to calculate weight of structural members in a Revit schedule?
Tip 14117:Recoloring of Inventor assembly parts - random, by material, by mass or other property (T4I)
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 12881:How to attach multiple raster images to my DWG in one go?
Back    All CAD Tips
Categ:
