CAD tip CAD tip # 8183:
Question
If you need to convert an existing 3D model in a surface representation (e.g. in the formats 3DS, IGES or STL) to a solid body, you can use e.g. Autodesk Inventor.
First convert your surface (mesh) model to format directly readable in Inventor. For 3DS files use AutoCAD (3DSIN, SAVEAS DWG), for STL format models use our web service STL2DWG.
Drag-n-drop the resulting DWG or DXF file into the Inventor window, or use the standard Open. In the import wizard (the 3rd step) use the option "Destination: New part", check "3D solids", "Use the default file names". Complete the import. Your model will be imported as a surface part. (If you load the surface in another way, you may need to use "copy to construction" in the browser tree.) Now you need to "stitch" the surface to a watertight 3D model.
Run the command Stitch (the ribbon Model > Surface > Stitch) and enter the tolerance for stitching of the surface facets. If neccessary, switch off the original surface model and assign material properties to the new solid model.
An example of a STL model in AutoCAD (faces only) and the resulting solid model in Inventor:
in AutoCAD
in Inventor
Note: precision of the resulting solid model is limited by the precision of the original facetted 3DS or STL file
See also the tip 9651 (video).
InventorACAD
1.9.2011   94077×   FAQ
this tip shared by ARKANCE experts applies to: Inventor · ACAD ·
Tip 15090:3DPlot - 3D math surfaces in AutoCAD.
Tip 15089:2DPlot - parametric math curves in AutoCAD.
Tip 14095:How to increase the accuracy (smoothness) of STL files exported from AutoCAD?
Tip 13472:How to convert the structure of a volumetric lattice to a real mesh body?
Tip 13013:Converting a 3D mesh to a 3D solid in Fusion 360.
Back    All CAD Tips
Categ:
