New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8181:
Question
If you need to round decimal numbers in drawing texts in AutoCAD DWG drawings, you can use the free utility CADstudio RoundT.
Download the add-on application from Download, load it with APPLOAD and run the RoundT command. After you select the texts, the command prompts for the number of decimal places to round. All selected texts (DText/MText and block attributes) which are pure decimal numbers will be rounded to the specified number of decimal places:
The application supports both point and comma as the decimal separators. A negative number of decimal places means that also the trailing zeroes will be displayed.
Using RoundT:
Since version 1.3 you can also use the command ROUNDT2 to round any decimal numbers inside longer strings and MText codes. Or use NumInText.
ACAD
1.9.2011    26432×
applies to: AutoCAD ·
Tip 14351:How to suppress trailing zeros in Inventor parts list?
Tip 14215:IF statement in AutoCAD text fields and attributes.
Tip 14095:How to increase the accuracy (smoothness) of STL files exported from AutoCAD?
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Back    All CAD Tips
Categ:
