Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11223:
Question
The freeware utility CCText (see) allows mass copying of selected texts from the current AutoCAD drawing to other Windows applications through the Windows Clipboard.
Select the drawing texts (line and paragraph texts, optionally also block attributes) and specify the ordering of clipboard texts. Then paste the copied DWG texts e.g. to Word or other application using the standard Ctrl+V (copy-paste).
The option "Attribs" toggles accepting attributes into the export. The texts are sorted to the Clipboard by default in the order of selection (as picked). Optionally you can order them by "X" (i.e. left-to-right), by "Y" (top-down), or by columns (top-down, then LTR). You can also preset automatic replacement of a given substring in the transferred texts.
By setting the variable _CCtextNoReformat you can disable automatic replacing of the control code \P with new-line in paragraph texts (MTexts).
(setq _CCtextNoReformat T)
You can download the CCtext (clipboard-copy text) application from DL Download, load it with APPLOAD and start it by typing the CCTEXT command.
See CCtext in a sample video:
ACAD
15.12.2016    11695×
applies to: AutoCAD ·
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14527:Search/Replace texts in Inventor drawings - iLogic.
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Tip 14335:Convert TrueType text in an Inventor sketch to a contour curve.
Back    All CAD Tips
Categ:
VRMLout More info
